W113 Pagoda SL Group => Wanted To Buy => Topic started by: joelpalmer on February 28, 2023, 22:06:26
Title: Exhaust Heat Shields full set ho many?
Post by: joelpalmer on February 28, 2023, 22:06:26
Need to buy a full set of exhaust heats shields for out W113 250 SL (early build).
Starting point; how many are there and what are the locations? Need to be servicable and able to be refinished
Thanks in advance;
Title: Re: Exhaust Heat Shields full set ho many?
Post by: dirkbalter on February 28, 2023, 22:31:36
Take a look here:
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/49-exhaust-systems/49-a-exhaust-system-standard
That should give you an idea on what you need. I believe the rear shield was not used on the 280's.
