W113 Pagoda SL Group => Wanted To Buy => Topic started by: EeVeeWee on January 08, 2023, 19:06:00
For my doors I'm looking for the Door Outer Chrome Top Trim Strip, for LH and RH side.
The OEM is 1137280130.
And also the chrome plate around the doorlock for the RH side, see picture.
Who knows where I can buy them in Europe for a reasonable price?
Thank you in advance.
In the meanwhile I bought new ones.
These pieces can be difficult to find and I believe that they are NLA. Since I have been in the process of restoring my 280SL have have become a bit of an Ebay (US) lurker and have rarely seen them. There are two posted on Ebay (US) at the moment: https://www.ebay.com/itm/225328936729?hash=item3476a6b719:g:4DIAAOSw1~hjszBA&amdata=enc%3AAQAHAAAAoA1B532bHsHPxudgIOFbH%2BTTfS7q%2FfncSkGv2q%2FhRbV50DpsP2HOtSORj6CmAWPIBRA9YEfovXmbUsPoXKHj6OHPvCf5wL8WSTDywWEtEWOrhNdXT1qPSaldq0Bj6D4ikdyoN5FSzd6LaL68J22PHettazi7Bvn%2BTCLvJN5S%2FqRmoHB%2B8Z6OA9bVFSkF6W6C33zevlSaqA3Hz%2BgQwySccpI%3D%7Ctkp%3ABk9SR4Lk1a-yYQ
I ended up having mine re-chromed and what this seller is offering may need re-chroming depending on your level of restoration. No personal interest here - just passing along information. Lee
Thank you Lee for the reply.
Unfortunately In don't have the original items, I bought a started project which is incomplete.
As I understand the LH and RH side are different?
I found these new parts (out of stock), but they seem the same for both sides.
https://oldtimer-ersatzteile24.de/Verchromte-Messing-Zierleiste-Tuer-oben-fuer-Mercedes-W113-Pagode
https://classic-mercedes-parts.com/en/module/iqitsearch/searchiqit?s=W113+door+chrome
Thank you, I saw the Chrome Cover Door Rear Right for €272.25 indeed.
But unfortunately not the door top trim.
Over the years I have found Alexander at: mbclassics.de. to be one of the best suppliers for our cars. He will also answer email or phone calls to help. I have bought quite a bit from them.
Here are some of parts you might be looking for:
https://www.mbclassics.de/chrome-molding-on-top-of-door-W113
I know of a guy in the Netherlands for used ones , pm me if you want his nr.
regards mark
Great link, thank you!
There are two trim strips at the very top of each door, one aluminum strip on the inside and one chrome strip on the outside. 113 728 0130 is the chrome strip on the outside and both sides are the same. (The aluminum strips inside are different from side to side). I see the part is out of stock at oldtimer-ersatzteile24 which is the problem I ran into. If it were me I would follow up with 450sl.
The chrome plates you seek are available from various sources and are different L and R.
OK thank you.
