W113 Pagoda SL Group => General Discussion => Topic started by: bpossel on June 11, 2005, 10:18:11
Title: Alignment
Post by: bpossel on June 11, 2005, 10:18:11
 :oops: I tried to get an alignment today, but didnt have any luck...
What I took with me were the following specs:
According to the 1969 Technical data book:
For 230/250/280SL:
Front camber: car in curb condition (full fuel, full oil, spare) +0 deg 10 sec (+ 20 sec). under test load 0 deg +20sec
Toe in (rolled) (in mm) 2 +/- 1, or 0 deg 20sec +/- 10 sec
Caster with mech steer - 3 deg 30 sec +/- 15 sec
with pwr steer - 4 deg +/- 15 sec
Kingpin inclination 5 deg 30 sec
Rear toe in (rolled) (in mm) 0 +/- 2 or 0 deg +/- 20 sec.
Rear camber +1 deg 30 sec, +/- 30 sec.
For some reason, the technician couldnt figure this out.  What he asked for were "Minimum, Preference, and Maximum" setting in degrees.
I did some conversions taking the above info and converting to degrees.  Does this table make sense to you?  Any advice?
Min, Pref, Max (in degrees)
Front Caster: 3.75, 4.00, 4.25
Front Camber: 0.17, 0.17, 0.50
Front Toe-in: 0.16, 0.33, 0.50
Rear Toe-in: -0.33, 0.00, 0.33
Rear Camber:  1.00, 1.50, 2.00
Thanks!
Memphis, TN.
1997 E320
Title: Re: Alignment
Post by: erickmarciano on June 11, 2005, 10:42:11
Hi Bob what is your fax # I will fax you the sheet  I got from The alignment place from their machine with min and max etc...
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
Post by: bpossel on June 11, 2005, 11:13:23
Hi Erick,
I dont have a fax number.  Could you scan it and email it to me?
robert.possel@stjude.org
If not, let me know and I'll see if I can find a fax machine, number.
Thanks!!!
Memphis, TN.
1997 E320
Post by: erickmarciano on June 11, 2005, 11:40:56
sorry don't have a scaner you can send the fax # to erickmarciano@hotmail.com
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
Post by: Benz Dr. on June 11, 2005, 12:09:52
Caster and camber usually won't move very much unless you have the whole ront end apart to install king pins.
I set the toe in close to 0 as it pulls in a bit at speed generating normal stability. Setting toe in to maximum will result in heavy tire wear.
 Rear camber moves all over the place as the swing axel moves up and down so what you want to look for is any measurments that are way out of spec. Some of this can be corrected using the cross strut or turning the spring plate. There's very little said about this on this site so I take it that people are either not interested or don't know about how to set up a rear axel. Until all the rubber bushings are replaced most of these adjustments are moot anyways.
Shock absorbers affect to overall handling of the car far more than you might believe so replace them if you have problems with handling that feels '' all over the road ''
Post by: bpossel on June 12, 2005, 02:40:34
Hi Dan,
Thanks for your comments.  I agree.  I didnt find any info on our site regarding folks adjusting the rear.  I did read in the BBB about adjusting the rear via the rear spring retainer (of course, need to have good rubber on the rear springs, etc).  Also note that my shocks are nearly new, ~1 year old and car doesnt move around on the road.  I wanted to get the alignment since I changed the front king pin and upper & lower control arm bushings, etc.  I dont have any record of an alignment ever being done, so thought that it would be good to do.
I will see if Erick can fax his spec sheet to my office tomorrow.  If anyone else has any comments on how they did their alignment, that would be great!
Thanks again,
Memphis, TN.
1997 E320
Post by: Bob G ✝︎ on June 12, 2005, 09:33:19
I installed John Olsons progresive rate springs, can you tell me if this will change aligment specifications ?
Post by: bpossel on June 14, 2005, 12:01:38
Hi All,
Still trying to obtain the "correct" alignment specs (in degrees) for the 280sl...
Please look at the attached file.  The table shows what I have calculated based on the bbb.  The rows highlighted in yellow show the alignment numbers from Erick (the place that did his alignment)
Can anyone shed any light on what the "correct" numbers should be?
Anyone else done an alignment?
Thanks!!!
Download Attachment: (http://images/icon_paperclip.gif) alignment specs.jpg (http://www.sl113.org/forums/uploaded/bpossel/200561414046_alignment%20specs.jpg)
49.43 KB
Memphis, TN.
1997 E320
Post by: George Davis on June 14, 2005, 13:25:15
For what it's worth, I checked your specs against the data book, and agree with all your numbers (not the ones in yellow).  However, the rear camber is measured WITH the hardtop installed (footnote 2).
Hope that helps.
Post by: bpossel on June 14, 2005, 15:50:45
Hi George,
Thanks for your reply and confirmation on the numbers!
Memphis, TN.
1997 E320
