W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: jsaylor on June 11, 2005, 03:29:28
Having just had new floors and rocker panels instaled I'd love some input on the best undercoating solutions for my ;65 239SL. Any input would be appreciated,
Jim Saylor
Kauai, Hawaii
'65 230SL
Hello Jim,
Be sure to clean the welds and bare metal with a wire brush or by sanding. Use a good rust inhibative primer on any bare metal. The Eastwood Company carries many restoration products. Also Rustoleum "rusty metal primer" is a good product (available locally) and will brush on easily. Use a finish top paint over primer then undercoat the areas. The factory used an "body schultz" (speeling?) which was a water based, thick, rubberized undercoat. A special "body schultz gun" is used to get the exact original texture. This product will accept a finish paint topcoat. The special gun is fairly inexpensive. I have used the Seikens "body schuttz" which I have been told was an original manufacturer for Mercedes. It worked very well and when using the gun the texture was perfect.
I have also used the 3M rubberized undercoat in the past. It has it's own applicator built in the aeriosol cans. The texture is not quite correct but it is a good product.
JOE,
dO YOU KNOW A SUPPLIER FOR THE "BODY SCHULTZ"?
RON GRICIUS
Hi Ron, I have seen a version of Body Schutz (from schutzen -- to protect) available at most automotive paint stores. 3M I think. There was just a thread discussing Wurth undercoating which may have been the true original material. The 3M looks to be close enough.
I think Wurth Undercoating is still available. Check in the web, for Worth products.
Wurth is no longer available. There were a few cans on Ebay last week but they are gone.
I think Wurth Undercoating is still available. Check in the web, for Wurth products
I found this link for Wurth in the US:
http://www.servicesupply.com/ (http://www.servicesupply.com/)
On this link, choose your country:
http://www.wuerth.com/web/en/wuerthcom/wrthweltweit/wrthweltweit_1/groupaddresses.php (http://www.wuerth.com/web/en/wuerthcom/wrthweltweit/wrthweltweit_1/groupaddresses.php)
These products below is what I use. I do not know if all Wurth Product ID are available in all markets
The rubber-based undercoating is Product No 0892 010
A good protective undercoating wax to go on top is Product No 0892 079
/Hans in Sweden
any photo from original pagode. . . or any from congours restore. . l
Here is the underside of an original 280SL, off the Motoringinvestments.com (http://Motoringinvestments.com) website
Note the light body-schutz with remains of wax overspray (the dark brown areas), as
well as the basic primer grey-brown showing in the transmission tunnel area, and red spray unevenly
dimming and becoming less, from the sides towards middle of car.
Note: exhaust pipes have been renewed (replaced)
/Hans in Sweden
Hi--
Check out this 3M rubberized undercoating in Beige.
http://www.autobodytoolmart.com/3m-rocker-schutz-beige-08874-p-11268.aspx
I haven't used the beige, but the black is great stuff.
Joe
WHO KNOWS THE ORIGINAL THINK FOR UNDERCOATING. .
For my 1971 280 SL project I used a different 3M product for the undercoating. It's called 3M 08800 Sprayable sealer.
It is best applied with a special spray gun from 3m(shown in the link) that gives a crinkle effect and with some practice you can
create a texture similar to the factory undercoating.
It's an amazing 2k product superior to anything else I've tried from Wurth and others.
Not cheap but worth it.
http://catalogue.3m.eu/en_eu/eu-aad/Sealers/3M_Sprayable_Sealer/Two_Part_Sprayable_Sealer/Two_Part_Sprayable_Sealer~08800 (http://catalogue.3m.eu/en_eu/eu-aad/Sealers/3M_Sprayable_Sealer/Two_Part_Sprayable_Sealer/Two_Part_Sprayable_Sealer~08800)
THIS PHOTO IS FROM MECHATRONIK GERMANY. HAT ABOUT THE UNDERECOATING US U CAN SEE..
The BBB lists the underbody protection as being "Teroson Caoutchouc Underside Protection Antirombo 2021" , I did try to find out more about this but did not get very far. I ended up using http://www.wurth.co.uk/catalogue/pdfs/UK-CD_08_0566.pdf (http://www.wurth.co.uk/catalogue/pdfs/UK-CD_08_0566.pdf) , this gave the closest finish to the original
Hello hkollan,
That looks like factory texture to me! Very much the same as the Sekkens Product I used to use with the special spray gun
Joe
The spray on bed liners seem to be pretty popular and so far I've only heard good things about it. Anyone try any of this on their under body?
I have considered Dupli-Color Bed Armor. It is water-based polyurethane with Kevlar. It would be exceedingly durable. The downside is it is only available in black but it is paintable.
I think that bed liner might be a bit too stiff. MB undercoating is pretty pliable stuff that I have yet been able to duplicate. Texture duplication is a challenge but possible with several different products out there.
That's the difference with the Dupli-color stuff. It's a water-based paint with Kevlar in it that remains pliable.
Well I might have to try it out then!
