W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Jean-Philippe Ringot on May 08, 2022, 11:47:01
Title: Indicateur de direction sur tableau ce bord
Post by: Jean-Philippe Ringot on May 08, 2022, 11:47:01
Bonjour ,
Mon indicateur de direction flèche verte droite ne clignote plus tout le reste fonctionne bien sur les phares et feux arrières . Peut on réparer changer une lampe derrière la flèche verte droite ou faut il changer tout le cadran rectangulaire central du tableau de bord ? Merci de votre aide !
Title: Re: Indicateur de direction sur tableau ce bord
Post by: yves on May 08, 2022, 12:30:46
Bonjour JP .... may be you can speak english here and translate the  answers...! y'll have much respons
Post by: AdelaidePagoda on May 08, 2022, 12:53:39
Translated for JP so he may get responses:
My right green arrow direction indicator no longer flashes everything else works well on the headlights and rear lights. Can we repair a lamp behind the right green arrow or do we need to change the entire central rectangular dial of the dashboard? Thank you for your help
Post by: Cees Klumper on May 08, 2022, 13:31:05
Ca depend .... it depends on whether the light itself is bad, or whether it's something else, like a bad ground or wire. Test the light first by applying 12 volts directly to it, and if it lights up, check whether the wire carries 12 volts when it is supposed to and, if it does, check the ground.
In any case, I don't believe the entire 'chassis' where the light is fitted would have to be replaced.
Post by: Jean-Philippe Ringot on May 08, 2022, 15:31:48
Thank you for your answer my question is how to access this lamp do you have to open the rectangular box to access it? The lamps that are behind are used to illuminate the dial?
Post by: dirkbalter on May 08, 2022, 15:54:22
Take a look here.
https://www.sl113.org/forums/index.php?topic=34910.0
Post by: Jean-Philippe Ringot on May 08, 2022, 16:06:14
Great ! This is what I was looking for so there are many lamps inside! Would you be so kind if you know the type and reference of the bulbs! Thanks a lot for your help !
Post by: dirkbalter on May 08, 2022, 16:24:42
Take a look here. Some guys like to replace the original ones with LEDs.
https://www.sl113.org/wiki/Electrical/InstrumentLights
