W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: ratoboy on April 03, 2022, 09:51:35
Title: power steering fluid leak
Post by: ratoboy on April 03, 2022, 09:51:35
My 1968 250 SL has a power steering fluid leak (power steering pump, hoses, seals, reservoir container, or O ring).  Does anyone have a suggestion on where to get parts?
Title: Re: power steering fluid leak
Post by: Pawel66 on April 03, 2022, 10:38:23
Mercedes Benz dealers, SLS, mbclassic.de, oldtimer-ersatzteile.de in Europe, Authentic Classics, Bud's Benz in the US.
Reservoir - ebay, this forum, junkyards, but not a lot to seal there, just one gasket (A 000 236 00 80) from Mercedes dealer and other places (just that from Mercedes you do not pay shipping, so price will be similar or it will be less expensive at Mercedes.
Recommend rubber parts (hoses) from Mercedes. Just that - I recently was looking for high pressure hose pump-box and in Mercedes it was NLA, I bought in SLS.
As for the pump - I believe in the US you have a lot of overhaul services (search the forum) if you want to rebuild it. Seal set available at Mercedes (A 000 586 31 46) and other places
More detailed info - if you provide more detailed needs. If you are planning on overall overhaul of the system - I would make a list and start checking the suppliers listed. I am sure there are many others as well.
Post by: MikeSimon on April 03, 2022, 13:14:10
Most common leak (except for loose hoses) is the shaft seal on the P/S pump. Not necessarily a DIY job if you don't know the pump well.
Post by: lagolag on April 22, 2022, 18:38:41
I did my powersteering pump in february, a strigh forward job, all p/n and tutorial can be found in the technical section.
MB dealer can supply the needed parts,  or you can buy from lots of different shops on the net.
