W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Pinder on February 18, 2022, 02:13:09
Title: Limited Slip Diff
Post by: Pinder on February 18, 2022, 02:13:09
So apparently my car has a limited slip diff. I recall I had topped up the fluids probably with the same stuff that  goes into a regular diff. Have I made a big mistake or can I just drain it out  and top up with the correct oil? It seems to work fine.
Title: Re: Limited Slip Diff
Post by: WRe on February 18, 2022, 10:12:42
Limited Slip Diffs need special oil, see workshop manual, according to MB 235.3.
...WRe
Post by: Benz280 on February 18, 2022, 15:05:21
I recently replaced my Diff oil ( Limited Slip ) Also.
Used Lucas 90 (Hopanoid ) most of the diff oils now sold are Hopanoid.
Post by: Pinder on February 18, 2022, 15:40:21
Ok it was a hapoid oil.
Post by: Benz Dr. on February 18, 2022, 23:36:52
I use a 100% synthetic gear lube with a LSD additive. Axle should growl when making sharp left or right turns at slow speed. That's the clutches slipping and nothing to worry about. Much louder if the additive isn't used.
Post by: MartinK on February 19, 2022, 20:05:50
Hei,
yes try a 75W90 or 80W90 Hypoid with LS oder LSD additive. For example Mobilube Syn LS 75W90 or 80W-90. Take care, Martin
Post by: Pinder on February 19, 2022, 21:39:29
thanks for the replies. Ill get it changed as soon as it gets warmer and crawl under there to drain it out and put the right stuff in.
