W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Pawel66 on November 20, 2021, 18:15:54
How much should I assume for exhaust getting longer as it gets hot? At the end of the pipes, after the rear muffler, there is this cross member between the pipes and I think it should be right under the rubber buffer there when the exhaust is hot. How much shall I plan for exhaust expansion when I am fitting it cold?
I only have experience from work on W463, shorter exhaust expanded good 2cm there.
Don't expect it to expand much Pawel. I never had any issues.
Ok, thank you!
