W113 Pagoda SL Group => General Discussion => Topic started by: MP on October 07, 2021, 15:35:14
Title: Side window jammed
Post by: MP on October 07, 2021, 15:35:14
I have a side window  jammed at nearly  full up it will move about 1" up and down.
I would be grateful for any ideas on where it is stuck I am hoping  to fix it in without taking it apart.
Maurice
Title: Re: Side window jammed
Post by: Peter on October 07, 2021, 17:54:44
Probably too much play or a window guide has come loose, unfortunately the solution is to open the door and adjust/repair.
Post by: MP on October 08, 2021, 08:48:04
Thanks Peter
Post by: gordon on October 08, 2021, 15:40:41
This is what you'll find inside. ( I'm about to put mine back together)
Post by: gordon on October 08, 2021, 15:42:25
Another photo
Post by: MP on October 10, 2021, 07:45:22
Thanks Gordon, does anything go in the the channel before the glass
Post by: gordon on October 10, 2021, 13:17:39
The metal jaws ( with plastic inner liners) slide  on the inclined metal rails at each side and also in the guide in the top of the slide rail adjacent to the A post.
The largest guide on the glass was missing on my driver's door and the other was loose as we're both on the passenger side.
I hope this helps.
Post by: Pawel66 on October 10, 2021, 13:53:18
mazmonza, when I was doing the glass replacement after mine broke, I went to the drawings of doors at MB EPC and on SLS and I bought all the plastic and rubber parts that are there and replaced them for new ones. Quite a lot of them there.
Also the clips rubber bumpers holding rods for locks.
There are rubber or fabric stripes between the glass and a rail holding it from the bottom. There are also 4 bushings going through the orifices in the glass for screws.
The jaws replacement process is very well described in the Tech Manual.
Post by: MP on October 11, 2021, 16:01:28
Thanks Pawel
