W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Paul99 on October 02, 2021, 13:14:05
I notice on the NGK website it suggests the E is a "better" plug than the ES. Same heat range and fitting etc, and they seem to cost a bit more.
I have used BP5ES and I believe the technical manual suggests ES but interested in the difference in performance/use if any between an E and ES plug?
NGK suggest the V shape centre of the E plugs will help with running.
Any thoughts?
Are you sure there is a BP5E? 5 is the heat range and E is the length of thread or in this case 19mm. Anything after the E is the firing end construction with S being a standard electrode. BP5EE perhaps?
attached the "How to read our part number: Spark Plugs" from NGK or here: https://www.sl113.org/forums/index.php?topic=30874.0 .
...WRe
The NGK website shows the BP5E as the same size exactly same thread etc but says of the BPxE plugs
Spark plugs with V-groove in the center electrode
The principle of NGK SPARK PLUG’s patented V-grooved spark plugs is technically simple but very effective. A V-groove is situated in the center electrode. This forces the spark to occur at the outer edge of the center electrode where it is easier to ignite the air-fuel mixture. In addition, the voltage required to produce a spark is reduced. These two features give the benefit of improved ignitability, especially in modern low-emission lean-burn engines, even under extreme operating conditions.
But I guess not really suited to our engines.
