W113 Pagoda SL Group => General Discussion => Topic started by: Zazozazo on September 21, 2021, 04:11:29
Hello all,
There is a number 130 016 08 01 with (0-9.3) above stamped near the spark plugs which in my opinion is not the engine number. What is it please ,and what does it refer to ?
Thank you
I would have thought it is more a casting number. Usually the system does not recognize these as part numbers...
Thank you :-)
Haven't we beaten that horse to death in another thread? ::)
It looks, that this head is from a late 280SL engine. You can check it as a full member in the Technical Manual.
The engine number would be further back on the block itself. Same side about three inches (75mm) from the rear of the engine.
The purchase of this car has been abandoned , too many irregularities and faults
Thank you to all for your help
I did expect some comments about the 9.3 compression ratio - if that's really what is on this head...???
Yes it is on the head, and unfortunately there is no engine number on the block. Only a new plate assuming the original engine number.
It actually should read 9.5. Another cylinder head mystery.
