W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: mdsalemi on September 20, 2021, 15:57:00
Title: Re-Keying OEM Chrome Gas Cap
Post by: mdsalemi on September 20, 2021, 15:57:00
Has anyone [successfully] had the OEM gas cap re-keyed?
I have one that isn't keyed "with the car" and curious to know if it is worth pursuing getting it re-keyed, or if this is even possible.
Title: Re: Re-Keying OEM Chrome Gas Cap
Post by: Vander on September 20, 2021, 16:46:10
Mike,
Yes, I have done it with success. If you mail it to Columbus, OH I can do it. Feel free to message me.
Post by: TJMart on September 21, 2021, 18:48:04
Michael,
Does your cap take a single sided key or a double sided key? I have both caps and am looking for the double sided one to be rekeyed to my master key. Have not been able to find anyone that can do it.
Post by: TJMart on September 21, 2021, 18:49:33
Vander,
Can you rekey a 2 sided key cap?
Tony
Post by: lreppond on September 21, 2021, 19:25:39
The newer 2 sided keyed locking gas cap lacks the two openings under the cork gasket.  These openings give access to clips which hold the lock in place. When compressed these clips allow you to disassemble and get to the tumbler and wafers.  So for two sided keyed gas caps the only way would be to drill holes to access the clips.
TylerS had volunteered to help me with this but time got away from me and then Covid. I have the necessary wafers IF we can gain access to the mechanism.  When and if we ever get around to this I will report back on our progress.
Post by: TJMart on September 21, 2021, 20:01:08
Len,
Thanks! that would be great. Have not been able to find anyone that can or is willing to do it.
Tony
Post by: stickandrudderman on August 03, 2022, 14:21:50
Did you ever resolve this issue?
I am looking at it and have drilled one of the two missing holes to access the lock lever but nothing has been revealed....
What I can say is that whilst the barrel in the locking cap that Mercedes supply uses a single sided key, the cylinder inside that cap has the reliefs to accept the wafers of a double sided key.
So, if you have a cap with single sided key that has the holes beneath the gasket with which to release the internal retaining lever, then all you need to do is find a supplier of the double-sided  lock cylinder. From there making your cap fit your key is straight forward.
Post by: LakisAkylas on August 03, 2022, 16:59:01
This is something I have looked into thoroughly. As far as I know, what Stick has suggested is the only way of re-keying a gas cap with two-sided key (for late 280SL). This idea was first implemented by Mark (Iconic) and I followed. The end result is satisfactory: a single key now works for ignition, doors, glove box, trunk and gas cap, as intended by MB. (According to my mechanic (Jim Cosgrove of Oldtimer Restorations), who actually did the barrel transplant, there is quite a lot of work involved though. He didn’t charge me for the time spent, but he would not agree to do it again for another customer!)
Lakis Akylas
71 280 SL, zf 5 speed, ltd slip, anthracite grey metallic (172), light grey MB tex (136)
Post by: stickandrudderman on August 03, 2022, 18:01:05
I spoke to Jim just now, he couldn't even begin to tell me how difficult it was to overcome this hurdle.... ;D
Post by: Shvegel on August 13, 2022, 16:28:04
Authentic Classics sells a reproduction without the Star logo.  This is a long shot but I wonder if the supplier of these caps would be willing to supply a keyed cylinder to swap into the original caps?  Might be worth getting ahold of Authentic classics.
Post by: stickandrudderman on August 15, 2022, 08:01:49
I believe all repros have single-sided keys so the cylinder from those won't help.
The double-sided key cap is not built to be dismantled so as Jim found out, it's next to impossible to do without running the risk of destroying the cap.
Post by: Jack Jones on August 17, 2022, 01:45:28
I have the newer 2 sided key and since I was unable to key the gas cap, I keyed all the other locks to match my gas cap. I have the kit to do this and have much experience with other makes so it was no issue.
Post by: stickandrudderman on August 18, 2022, 08:20:23
Good call!
Post by: caddyladdy on July 06, 2024, 20:07:13
Larry,
I know your post is quite old . . .  wanted to chime in and report that I have cracked the code on caps with no access holes.  I am interested to know more about your wafer collection . . .
regards,
hap
Post by: caddyladdy on October 21, 2025, 23:05:53
HP Key has cracked the code!  Contact me . . .
