W113 Pagoda SL Group => General Discussion => Topic started by: hands_aus on May 02, 2005, 05:19:09
Title: Grommet part number needed
Post by: hands_aus on May 02, 2005, 05:19:09
I need the part number of the GROMMET where the wiring harness comes out of the body (front left hand side further under the wheel arch) and goes to the auto transmission terminal block.
RHD car BTW, don't know if that makes a difference.
I need the part number of that grommet please.
The grommet hole measures at about 25 mm.
Title: Re: Grommet part number needed
Post by: Mike Heagney on May 04, 2005, 08:08:43
Hi Bob
Trans cable grommet to footwell.....# 111.997.15.81
Cheers,
Mike.
64 230 SL  in bits.
Post by: Naj ✝︎ on May 04, 2005, 10:39:29
Mike,
Would you also have a part # for the reversing light cable grommet - also on left footwell?
Post by: Jonny B on May 04, 2005, 21:44:56
Only a word of caution. The part number that has been listed here starts with 111 or the body number for that series cars. I thought that part numbers that went across a range of MB models had a more generic start to the part number (100 or similar) and that part numbers that had the specific body designation were unique to that style. I am traveling and do not have the parts manual to refer to as a reference.
Post by: hands_aus on May 05, 2005, 05:41:04
Hey Mike,
Thanks for that info.
BTW how is the resto going, out of the boxes yet?
Post by: rwmastel on May 05, 2005, 19:11:13
Jonny,
Opening my 230SL part book to a random pages, I found part numbers starting with 110, 111, 112, 120, 127, 136, 180, 186, and more.  I think if it was designed for one chassis, then was used in a later one, then they kept that part number.
Post by: Jonny B on May 06, 2005, 10:04:34
Rodd,
Thanks for the clarification. That sounds like a pretty logical explanation.
