W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: ChrisInNashville on May 22, 2021, 19:38:27
So, a little while ago, I posted an SOS since the rear bow of my soft top was jammed and wouldn’t fold up.
(https://live.staticflickr.com/65535/51195705106_592268e660_z.jpg) (https://flic.kr/p/2kZZnuN)
I deleted the post when I found some outstanding instructions in the technical manual
https://www.sl113.org/wiki/Tops/SoftTop
But, it still didn’t work. In the technical manual, there’s a sequence noted and then an addendum referencing a “release lever” in ‘70/‘71 models. My ‘69 has the release lever. Using the release lever, I was able to partially fold the top, but the rear bow was still jammed.
I simply grabbed some rope and threaded it around the soft top frame including the rear bow and pulled hard and that unjammed everything.
A happy ending for my day...
It happened to me once, when I was the first time user.
Ideally, you want the whole roof assembly to pivot out of the compartment. Once you clear the softop compartment lid, you want to get the lid down and secured. From thereon is easy.
If you get stuck, much like your picture shows, I notice it helps to put the soft top back into the compartment and try slowly to pivot it out of the compartment. It may require some force, but the frame is flexible enough to come out of there.
Agreed. In this case, it happened while I was folding it and it wouldn’t allow me to complete the fold. It got 95% folded, but wouldn’t get all the way and there was no place for me to get my hands around things to apply force. Alas, I’m happy...but sore for 30 minutes of trying to force it before I found the technical manual
I don't know if he still has them, but mrfatboy used to sell a "bow buddy" that works beautifully!
https://www.sl113.org/forums/index.php?topic=29865.msg216324#msg216324 (https://www.sl113.org/forums/index.php?topic=29865.msg216324#msg216324)
What an awesome invention!
Thanks for the kind words. I sold out of all my Bow Buddies over a year ago. It is a life saver 👍.
Maybe I should make more? 🤷♂️
Maybe you should ;D
I'd be in for one...
Count me in for two please !
Count me in ;)
If there is enough interest by June 1, 2021, my wife and I will consider making another batch ;D
Please go to this thread and let me know if interested.
