W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Tom in seattle on April 12, 2021, 23:21:07
Title: Short Fuel Pump Wiring
Post by: Tom in seattle on April 12, 2021, 23:21:07
I have my short pump out and forgot to photo it before removal.  I believe the wire posts are labeled 30 and 31.  I believe the pump can run backwards if wired improperly.  Can you tell me which post is negative and is it left or right side.  Thank you for your help.
Title: Re: Short Fuel Pump Wiring
Post by: Rolf-Dieter ✝︎ on April 13, 2021, 00:50:20
Have you tryed our site Search or GOOGLE Tom?
Hoope the taachement helps you somehow.
Dieter
Post by: Leester on April 13, 2021, 23:27:07
According to the wiring diagram terminal 30 gets 12v and terminal 31 is ground.
Post by: Tom in seattle on April 14, 2021, 02:47:44
Thank you Leester and Rolf Dieter.  I have it wired properly now. All is well.
