W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: CJHenderson on April 10, 2021, 12:41:07
Title: Transmission shaft and wiring
Post by: CJHenderson on April 10, 2021, 12:41:07
While cleaning the transmission I noticed that the input shaft can be wiggled by hand. Is this normal? Also the three wires that is on the transmission is in very bad condition. Can I order a new one or just build one?
Title: Re: Transmission shaft and wiring
Post by: cfm65@me.com on April 10, 2021, 13:42:52
Hi CJ,
Yes, the shaft is supposed to be a little loose.I am sure you could easily make up new wires.
Chris
Cape Town
Post by: CJHenderson on April 10, 2021, 14:15:15
Thanks, that just took a load off of my mind.
Post by: cfm65@me.com on April 10, 2021, 20:17:03
Yep, I believe they are all the same, from Model T%u2019s to Porsches and Ferrari%u2019s. The idea is not to have an absolute rigid/perfect connection between the engine and transmission. Just a little play is quite common on most cars I have seen.
Chris
