W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: scoot on April 03, 2021, 16:41:40
Title: Help requested identifying assorted small parts...
Post by: scoot on April 03, 2021, 16:41:40
Hi, here's one of my special parts bins.  There are some parts that I don't know what are.  Any comments/edits/ideas would be appreciated.
1.  Stainless steel wiper hold down nut
2.  Plastic finger nuts that hold down dash wood
3.  Horn pad retaining gizmos
4.  UNKNOWN thumb screws - what are these for?
5.  Misc. tail light retaining nuts
6.  Emergency bezels for early hazard switches
7.  Early chrome wiper caps that screw on - really heavy - what cars are these for?
8.  Long odometer/potentiometer knobs - what are these for?  W111 coupes?
9.  Unknown small thumbscrews. ?
10.  Vent levers for ? - badali says they are later heat levers for 111 sedan.
11.  Vent levers for ?
12.  Chrome vent levers - maybe for W111 coupes?- badali says they are early heat levers for 111 sedan.
13.  AC knobs - for which units?
14.  Part of rear view mirror.
15.  Misc switch knobs
16.  Small AC knobs - for which cars?
17.  Ivory seat back release/turn signal knobs
18.  Misc bezels
19.  Thumb screws for what?  Clocks on a W108?
Title: Re: Help requested identifying assorted small parts...
Post by: Vander on April 03, 2021, 16:53:16
Is #4 the thumb screws that hold down the carpet covered boards in the back seat area of a W113?
Post by: scoot on April 03, 2021, 17:08:33
Good guess, but my recollection is that those thumb screws aren't internally threaded all the way through to the top.  In other words, I think the part for the carpet cover is flat on top, not showing an internal thread.
Post by: GM on April 03, 2021, 17:10:06
On first look, I thought the #4 knobs were for that too, but the knobs/screws holding down the parcel shelves are male
Post by: scoot on April 03, 2021, 17:12:09
Good call.  I had forgotten that.  They are male.
Post by: badali on April 03, 2021, 17:16:05
12 is the early heat levers for 111 Sedans.  They are plastic in later models for impact protection.
10 is for later model 111 sedans.
Post by: 66andBlue on April 03, 2021, 19:01:46
#19 could be the knobs that clamp the bulb holder to the front of the central instrument cluster.
https://www.sl113.org/wiki/Electrical/Rheostat?action=download&upname=Rheostat_removal.jpg
Post by: GM on April 03, 2021, 20:11:11
Further to Alfred's note above, also for connecting the tach, speedo and clock to their rear mounting brackets?
Post by: TOMNISTUFF on April 03, 2021, 21:01:32
#1 are press-in grease fittings, 2 per door (1 per hinge).  Be careful mine were screw-in and instantly broke when I tried to remove them because they were plugged and wouldn't accept grease.  I had to drill them out and press in the ones you call #1.  By the way, if you order the original screw-in type by part number from Mercedes, you will still get the press-in version and have to rework your door hinges for them to work - don't bother to ask me how I know.
Tom Kizer
Post by: majercak on April 05, 2021, 18:43:26
#16 - some of them look like Becker radio knobs - TR/slim face version
#18 - some look like Becker radio high/low switch, again TR/slim face version
Post by: Benz Dr. on April 05, 2021, 22:06:20
12 is early 190SL levers. Probably used on sedans from the same era.
Post by: Desertpagoda on May 09, 2021, 23:41:17
#8 you also used to see the longish odo knobs in a flexible material
Post by: TJMart on May 11, 2021, 20:22:47
#13 look like the knobs for the under dash Frigiking Unit
Post by: TOMNISTUFF on May 12, 2021, 11:57:46
In my earlier post, I misidentified the wiper shaft caps (#1) as grease fittings.  A closer look reveals that there is no hole or grease gun cone.  Sorry.
Tom Kizer
