W113 Pagoda SL Group => General Discussion => Topic started by: Benz280 on March 29, 2021, 13:03:13
Title: Clunk Bushing - Differential
Post by: Benz280 on March 29, 2021, 13:03:13
Have identified a slight clunk when accelerating and deaccelerating from the differential, flex joints / joint's all ok.
Occasionally, I hear about the Clunk Bushing - or just a slightly worn pinion gear ?
Owning a Pagoda is constant quest for more knowledge  :)
Title: Re: Clunk Bushing - Differential
Post by: Bonnyboy on March 29, 2021, 15:15:56
I had an odd clunk and after checking everything it turned out to be a loose brake caliper - just loose enough to make a clunk.
Worth a try.
