W113 Pagoda SL Group => General Discussion => Topic started by: bpossel on April 19, 2005, 06:19:57
Does anyone one know a vendor who carries the plastic hose that connects the brake servo to the manifold? See attached pic (yellowish hose...)
Thanks!
Download Attachment: (http://images/icon_paperclip.gif) plastic-hose.jpg (http://www.sl113.org/forums/uploaded/bpossel/20054198193_plastic-hose.jpg)
79.51 KB
Memphis, TN.
1997 E320
Thanks!
Why yes I do. That hose is the vacuum hose (provides the "power" to the vacuum-assisted power brake servo) and the part in the middle is a check (one-way) valve.
A vendor to try is Mercedes Benz. I replaced mine last year, cost about $18, in stock at Caliber--though if you don't have a bunch of parts might pay to just pay list locally and avoid shipping charges.
If all you are interested in is a non-yellow hose, and you are not showing your car, you can get a semi-rigid hose at many plumbing supply places, even The Home Depot; it is polyethylene, or "PE" You can't use really flexible stuff like Tygon or vinyl; will collapse under vacuum. Cut out the old pieces, replace with new. Use hot water to soften the ends.
Everything on these cars should be so easy to deal with..[:(!]
