W113 Pagoda SL Group => Electrical and Instruments => Topic started by: marshall on February 26, 2021, 17:08:58
Title: Spare Injection Pump
Post by: marshall on February 26, 2021, 17:08:58
I have an second fuel injection pump out of my '71 280SL. It's complete but probably in need of a rebuild. What would be an appropriate value of this pump? Thanks from suburban Philadelphia.
Title: Re: Spare Injection Pump
Post by: Cees Klumper on February 27, 2021, 03:30:17
It would be great if you can have it tested properly. Because the difference between a pump needing a rebuild, and one that has been tested and is ok, is probably a significant amount. I understand that these rarely need to be rebuilt, so you may be ok with yours. If it is in good shape, I would think it's worth at least around $1,750.
Post by: Peter h on February 27, 2021, 06:12:27
If it is a 24y ESP for a 71 US, the price should not be very high, at least in the EU.
In my experience, it makes no sense to reset a 24y. It is better to buy an EU pump and readjust it because of the changes.
In Europe, this 24y would hardly sell over 500 EUR.
A 24 is double that.
I have had quite a few pumps reset. None of the measured values ​​in the initial protocol were OK after 50 years.
Certainly, almost all of them run somehow.
Post by: hansr433 on February 27, 2021, 12:01:55
Peter, whom would you recommend to do a full pump service?  My car is a 1963 220SE Cabrio with M127.984 motor (2 piston FIP).
Hans
Post by: Peter h on February 27, 2021, 14:19:17
https://www.oldtimer-technik.eu/
