W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: CJHenderson on February 11, 2021, 16:53:44
Title: Coil spring compression tool
Post by: CJHenderson on February 11, 2021, 16:53:44
Curious as to where to get a coil spring compression tool. The one that I bought from Amazon is the type that the compressor shaft goes through the center of the spring and through the plates. The one that I have the plates do not fit properly on the springs.
Title: Re: Coil spring compression tool
Post by: Benz Dr. on February 11, 2021, 20:34:45
Which spring are you trying to compress?
Post by: CJHenderson on February 11, 2021, 22:10:09
Front wheels
Post by: CJHenderson on February 12, 2021, 00:44:55
Found one at Pelican Parts specifically for 63-71 SL class. P/N PEL-013845SCH01A
Post by: merrill on February 13, 2021, 13:56:52
hi
if you search the forums or tech manual you will find a technique to remove the front springs without a compressor.
Post by: Pawel66 on February 13, 2021, 15:38:56
Yes, there is a technique to do it - also in Haynes and BBB. But it is so scary....
Post by: dirkbalter on February 13, 2021, 16:48:26
CJ,
may be that helps. Worked good for me.
Post by: CJHenderson on February 13, 2021, 21:54:39
Really is a good idea but since I ordered the tool I'll try it but if that fails I will resort to what you did. Thanks to all for the advice.
Post by: PeterPortugal on February 14, 2021, 10:16:22
CJ / Dirk,
I did both. I think it depends on the timing. If it is in the middle of a restoration and is high up with no engine installed that is one thing. Mine was just raised on axle stands. I think the 10mm threaded rods are essential for safety.
What I found is that the compression tool bought me enough room to safely get the springs and rods installed. Once this was done I tightened up the nuts on the rods to take up the slack. I then removed the compression tool and finished the job using the nuts on the threaded rods.
It took me a few attempts to optimise the position of the plates in the spring to make sure they compressed it enough and I could still get them out when the spring was fitted.
