W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Mpgeslak on January 13, 2021, 21:05:34
Hi All,
Two questions I am looking for assistance with:
1. I am trying to locate where on the Front Axle the serial number is stamped. Based on the Data Card, it should be stamped on both the left and the right side. I have looked everywhere, but cannot find it.
2. Will a steering gearbox with part number 112 461 0501 from a 280SE fit in my 250SL?
Any help would be appreciated.
Michael
The steering box from a 280SE should be the same as for your pagoda. However you may need to use the original pitman arm from the pagoda steering box. Look for the I.D. # cast on the pitman arm to identify them.
Thanks Joe, I appreciate the insight.
