W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: sgp on September 06, 2020, 12:58:34
Hi guys,
I am very low on power steering fluid. Currently the car (250sl) seems to have red ATX fluid. I am looking to change it to Febi-Bilstein Power Steering Fluid 08972 and of course will perform a system flush to replace this fluid plus replace the filter.
Do you know how much Febi-Bilstein Power Steering Fluid will I need (I already bought 1q of this liquid)?
Thanks! :D
1.4 Liter
...WRe
May want to check if the fluid you are going to use delivers on MB norm 236.6. If not, use one that does.
Thanks I'm using https://www.pelicanparts.com/More_Info/Q1460001M36.htm?pn=Q-1-46-0001-M36&bt=Y&fs=0&SVSVSI=W113
It seems to be MBZ Approved:236.3
Will it work?
Good question, actually.
In the Maintenance Manual we say: Automatic transmission fluid (ATF) spec. MB 236.6
Here we say 236.3
https://www.sl113.org/forums/index.php?topic=27816.msg202314#msg202314
Which one is it? Got confused myself, I thought I knew that...
