W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: EeVeeWee on September 01, 2020, 19:11:57
Title: Fuel lines
Post by: EeVeeWee on September 01, 2020, 19:11:57
I am installing the refurbished fuel pump from my 230 SL and bought new fuel and brake lines.
For underneath the bottom I made and found some usable pictures of the position of the lines and how they are connected. But at the front of the car I am not quite clear about that. Can anyone show pictures of the position of the brake and petrol lines in the engine compartment?
Thank you in advance, Eric.
(https://www.mupload.nl/img/tlq7p4us6.03.2014).jpg)
Title: Re: Fuel lines
Post by: MikeSimon on September 07, 2020, 14:02:48
I can take some pictures later today, if the rain stops. In the meantime, please allow a question: Where di you buy the fuel lines? Were they pre-formed and cut?
Post by: sandcrab59 on September 07, 2020, 17:20:18
My experience with Mercedes fuel and brake lines has been, they come in a roll and you have to unroll the roll and carefully match it to the old lines.
You might need a line bender so that you do not kink the line.
Also I have found out on my Mercedes cars is that the fuel lines for feed and return are different mm's. Be careful.
Post by: 66andBlue on September 07, 2020, 17:37:12
Perhaps these might help you. Let me know which area you need to see.
Post by: EeVeeWee on September 08, 2020, 19:07:05
Thank you very much!
The next question is how are the brackets mounted?  :o
There are holes reachable from above the floor but some are in a closed compartment.
So what kind of bolts are used for these brackets?
(https://www.mupload.nl/img/7oay5m8lj3tt6.jpg)
Post by: EeVeeWee on September 08, 2020, 20:24:31
I found these bolts before, but you still must be able to reach the holes from the upper side which is not everywhere possible.
And not every hole is square.
Or am I missing something?
(https://www.mupload.nl/img/vby47d3.21.29.png)
Post by: Shvegel on September 12, 2020, 08:27:23
Some of them use hex headed sheet metal screws where the bracket falls into a boxed section.
If you are making your own flares do the flares for the engine ends before you install the lines.  From experience trying to get enough torque the flare a 10mm line next to the frame and engine really sucks.
Post by: Pawel66 on September 12, 2020, 08:56:58
From the parts list I see:
N 000085 006124 SCREW Replaced with N 007985 006133
then
N 007985 006133 SCREW FUEL AND BRAKE LINES TO FRAME FLOOR UNIT 3pcs
I also see
A 120 420 02 27 SCREW W RECTANGULAR HEAD FUEL AND BRAKE LINES TO FRAME FLOOR UNIT 1 pc (this is the one shown in post below)
And I got a bit confused as 1 of those latter ones is needed for fuel pump bracket to trunk floor fixing. This would suggest that this 1 piece from parts list is for fuel pump rather than the fuel lines. But I am not sure if this is true.
I see just tapping screws in the parts list for the front support fuel line fixing.
Post by: Naj ✝︎ on September 16, 2020, 13:36:40
These may help
Post by: Naj ✝︎ on September 16, 2020, 14:09:06
Couple more
Post by: EeVeeWee on September 16, 2020, 14:27:27
I am very happy with these pics, thank you very much!
Post by: sandcrab59 on September 20, 2020, 11:19:19
Great Pictures NAJ.
Is that your car?
Hope you are feeling Good.
Tom M
Post by: Leester on September 20, 2020, 16:15:59
My thanks to you, Naj, as well. I am in the midst of doing these brake, fuel lines and brackets myself. Photos at Motoring Investments were helpful but yours are much better. Thanks again. Lee
Post by: Naj ✝︎ on September 21, 2020, 10:53:55
Great Pictures NAJ.
Is that your car?
Tom M
I.m good, Thanks, Tom
The dirty one may be my 230, Not sure
The blue one was on a ramp on the Mechatronic stand at TechnoClassica at Essen in 2009.
