W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: yves on September 01, 2020, 13:41:24
Title: Injection pump refurbishing adress in France or Europe?
Post by: yves on September 01, 2020, 13:41:24
I have some difficulties to start the engine when cold,  ( the engine starts after 10 seconds without throttle and after a first trial of 10 seconds too ) the engine is ok when hot .  i have replaced the 6 sparks plugs, checked the distributor by a mechanic and this one says that the pump needs to be adjusted ( he says also that the "fumes" are very black at the exhaust and the old plugs were black too.
AFAIK  the pump refurbishing is a tricky job , so i'd be very happy to have an adress here in France or Germany  at a professional mechanic for that...!
Thank you !
Title: Re: Injection pump refurbishing adress in France or Europe?
Post by: VincentR on September 01, 2020, 13:50:43
You can contact : http://www.etoile67.com/
They are specialized in old Mercedes injection.
They are serious and professionnal.
Have a nice day !
Best regards.
Vincent R
280sl 1970
Besançon / France
Post by: yves on September 01, 2020, 16:32:18
Thank's Vincent ;)
Post by: Taleb on September 01, 2020, 21:01:09
The right company is www.koller.de speak with Rainer stahel +49 172 3442206
Good luck
Post by: WRe on September 02, 2020, 06:37:11
see https://www.sl113.org/forums/index.php?topic=30847.msg223857#msg223857.
CMG are doing a pre-analysis with error report for ~150€.
...WRe
