W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: jklcycles on August 14, 2020, 00:43:34
Title: Hasn't run in 24 years
Post by: jklcycles on August 14, 2020, 00:43:34
My 1966 230SL hasn't ran for 24 years. It was running when parked back in 1996. I want to spin the crankshaft and check the compression. If the mechanical fuel injection system is gummed up with old fuel, can I damage the fuel injection system when I spin the crankshaft? Thanks in advance, Jack.
Title: Re: Hasn't run in 24 years
Post by: MikeSimon on August 14, 2020, 13:02:09
Eager to hear some answers about that.
Post by: ja17 on August 14, 2020, 14:38:17
I would suspect that the electric fuel pump is stuck, but I would pull the fuse for it so you do not circulate dirty fuel to the IP just in case it still runs. Pull all the spark plugs and squirt a little lube in the cylinders.
Post by: ejboyd5 on August 14, 2020, 18:19:31
I would turn the engine over by hand before putting power ti it.
