W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: McBenz on August 08, 2020, 17:03:09
Title: New Water Pump break-in period?
Post by: McBenz on August 08, 2020, 17:03:09
I replaced the water pump on my 230 sl and I seem to have a small coolant leak. I read a Gates memo that indicated that all types of water pumps have a mechanical seal that has a break-in period of about 10 minutes of running, and that seepage from the weep holes is to be expected at the beginning. Is that the case of our water pump (4 holes-long version)?
Title: Re: New Water Pump break-in period?
Post by: Desertpagoda on August 15, 2020, 19:12:34
this is news to me have done hundreds of pumps?
Post by: Benz Dr. on August 15, 2020, 20:31:16
I think if you had a new pump and it started to leak that you might want to return it. I've checked water pumps by using a vacuum pump on the leak-off hole. If it won't hold a vacuum, it won't hold coolant pressure either.
