W113 Pagoda SL Group => Wanted To Buy => Topic started by: Merc_Girl on July 07, 2020, 08:16:14
Title: Wanted: early window winder/crank for 230sl
Post by: Merc_Girl on July 07, 2020, 08:16:14
Hi folks
I have discovered that my 230sl has two different designs of window winder/crank, with the passenger side having the latter design.
Does anyone happen to have any early version please
Thank you
Katie
Title: Re: Wanted: early window winder/crank for 230sl
Post by: scoot on July 07, 2020, 15:01:13
There are three versions of window cranks:
1.  Early small knob, held in by a screw
2.  Middle, big knob, held in by screw
3.  Late, big knob, held in by a clip that is part of the crank insert pad (the upholstered colored thing)
You have a 230 SL so you should have the small knob version, the first one.  Are you saying that your window cranks don't both look like #1?    Pics attached.
Post by: scoot on July 07, 2020, 15:02:09
I think what can happen is at some point your window regulator gets replaced and it gets replaced with the later style (that doesn't have a screw to hold in the crank, so your crank gets replaced with the later style also.  Is this what has happened with your car?
Post by: scoot on July 07, 2020, 16:11:34
Oh, and for what it's worth I have all types of window cranks...
Post by: 66andBlue on July 07, 2020, 17:20:52
Hello Scott,
great info; please add it to our technical manual. https://www.sl113.org/wiki/ChassisBody/Windows
Thanks.
Post by: Benz Dr. on July 07, 2020, 17:40:34
Yup. That Scot guy sure has a good handle on things.
Post by: wjsvb ✝︎ on July 07, 2020, 18:04:24
Amen to that!  He's good on Becker radios too! The window handle guide should be in the Tech Manual!
Post by: scoot on July 07, 2020, 18:21:09
OK, I'll put the window handle guide into the tech manual, along with samples of which types of crank insert fit for each one...   :-)   Scott
Post by: Merc_Girl on July 07, 2020, 19:15:12
Hi chaps
Thanks for your replies.
So, the drivers door has the first style, which is the correct one, with a small knob.
The passenger has a different design, which is incorrect and the one I need to replace, if I can
Pictures attached
Post by: Merc_Girl on July 07, 2020, 19:29:17
Once I’ve replaced the incorrect one I will have a #2 style window winder/crank handle available if someone needs one 😂
Also, I know I may be being a bit odd, but it seems ver ‘unGerman’, but the windows operate in different ways:
- drivers side the winder is turned clockwise to lower the window
- passenger side, if the winder is turned clockwise it raises the window!!!
Is this normal???
Post by: scoot on July 07, 2020, 19:34:05
I need a picture of the passenger side, without the crank insert installed.  Then I can tell you the answer.
Post by: Merc_Girl on July 07, 2020, 20:34:18
So, this is the wrong design for the year, although it does appear to have a small knob?
Post by: scoot on July 07, 2020, 21:29:47
No, that is perfectly correct.  You said the passenger side doesn't match.  Attach pic of the passenger side that doesn't match.
Post by: ja17 on July 07, 2020, 22:51:56
Most Mercedes sedans of the era W110, W111, early W108 with manual windows also used the early style window crank.
Post by: scoot on July 07, 2020, 22:59:35
...which is why I have a nice box of them...  I used to do a lot of junkyarding...
Post by: Merc_Girl on July 09, 2020, 21:49:58
With thanks to all my fine SL113 friends for all your helpful pointers.
Now sourced the item needed from one of our group members
Take care
Katie
