W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: mikeswplt on June 25, 2020, 19:47:23
Title: Wiper motor installation Question
Post by: mikeswplt on June 25, 2020, 19:47:23
I am restoring my 250SL and while cleaning the wiper motor for installation I noticed what appeared to
be a caulk material on the bottom of the base where it attaches to the body. It was only at each of the 3
bolt holes and apparently to prevent water from getting in. Was this something the factory did or the result
previous maintenance? Appreciate any insight , thanks.
Mike
Title: Re: Wiper motor installation Question
Post by: doitwright on June 25, 2020, 22:13:32
That was a flexible sealant done at the factory. I only say that because I have it on my wiper motor also.
Post by: mikeswplt on June 26, 2020, 13:54:15
Thanks for the info Frank, appreciate it.
Interestingly my 250 SL was light beige now anthracite gray metallic.
Post by: Shvegel on June 26, 2020, 23:48:44
Do an Amazon search for "Strip caulk"  Mortite brand?
Post by: Pawel66 on June 27, 2020, 08:42:36
Just to make sure - you know that there are 3 rubber seal rings around the bolts (A 201 987 02 41) and the isolating pad A 110 824 01 97.
I understand what you talk about is an additional seal.
Post by: mikeswplt on June 27, 2020, 14:51:29
Thanks Pawel
I wondered if rubber washers were used. Mine were missing after many years of being apart. The isolation
pad is attached to the base of the motor. Thanks for the part numbers.
Mike
