W113 Pagoda SL Group => General Discussion => Topic started by: Benz280 on May 28, 2020, 16:53:53
Title: Valve Adjustment Frequency
Post by: Benz280 on May 28, 2020, 16:53:53
How often does the group recommend doing a valve adjustment on the M130 ?
Any indicators that an adjustment is necessary, have no idea when the last one was performed.
Title: Re: Valve Adjustment Frequency
Post by: ja17 on May 29, 2020, 05:22:26
A valve adjustment and head re-torque every 12,000 to 15,000 miles should keep things in order!
Post by: Pawel66 on May 29, 2020, 08:24:24
We have this great resource here, that I use and admire: https://www.sl113.org/wiki/Restricted/ServiceManual
If I did not know when the adjustment was made, i would just do it probably. Good moment to look at cams and chain.
I guess the engine gets a bit more noisy when valves are out of adjustment, vacuum may be weaker, do not know what else...
Post by: Vander on May 29, 2020, 12:05:30
As JA17 says every 12k miles. Any W113 car i get in and don't know when it was last done, it is one of the first things I do.
