W113 Pagoda SL Group => General Discussion => Topic started by: Merc_Girl on May 28, 2020, 07:33:40
Dear honourable friends
I’m in a quandary as to what to do with our garage floor.
My Pagoda is still in lock down, so despite being in 90% ownership, it is still tucked up safely in Warwickshire (UK).
So whilst pinning for my car, I thought we would ‘do up’ the garage to welcome her into her new home, and to make it a worthy place for her presence.
My problem is the floor. There is some shaling on the surface in areas. From research undertaken there seems to be a few options
a) self level the surface and paint (garage floor paint)
b) epoxy paint (not sure if surface needs levelling first)
c) floor tiles
Your thoughts and experiences most welcome
Katie
100 percent solids Epoxy but a job best left to professionals. I had mine done by a couple guys who were moonlighting from a company that did large factory floors. Clean floor, grind floor, grind open cracks and fill with caulk the coat with primer then finally a top coat. I am very hard on my floor and I have yet to chip it.
I am about to do the same for my new garage floor.
Shevgel, was that a two pack epoxy used. I have used paving paint in the past but not that impressed.
I too would have it done professionally. There is a LOT of prep that is absolutely required, and also specialized (grinding, acid wash etc). I have a floor I did myself, it hasnt lasted. Where as the professionally applied epoxy at my shop looks perfect still. The floors are about the same age.
Another vote for epoxy, professionally prepped and applied. I did my shop 12 years ago an dit continues to hold up great.
I am going to go against the grain here
I have Ecotile flooring in my garage (and my old one). Fabulous stuff and even a cack-handed idiot like me can fit it. Ecotile sometimes do deals on "over-runs" on ebay (see below) but I got my current lot from a warehouse that relocated.
https://www.ebay.co.uk/itm/Garage-Flooring-24-Square-Meters-x-Heavy-Duty-Interlocking-Floor-Tiles/353086448706?hash=item523597a442:g:oSsAAOSwYoFey3kL
I got my 24m2 in the back of my old Evoque easily enough.
Here is another vote for professional application of epoxy finish. Grind, clean, prep and application. 7 years and still looks great.
Norm
I don't know about UK prices, but a standard 2-car garage in the USA with a professionally applied epoxy or epoxy like coating costs ~$2,000.00. Depending on location, competition and exact materials and prep, I've seen it as high as $4,000 and as low as $1,200. I should note that a number of my neighbors, all thinking they could do it themselves with a kit from a home center, tried it and all failed. Nobody has that kind of surface grinder, and nobody did the level of prep that a pro can do. It's not the chemistry, it is all about the base prep.
My garage floor, poured in 1992, wasn't in the best of shape. In a perfect world, and one in which I had planned on staying in the home, I probably would have replaced it. But we moved last year, and we knew we were planning on a move in 2016 when we had it done.
We chose a polyaspartic coating which is a bit higher grade and cost than just epoxy, though it is quite similar. They used a huge surface grinder to prepare the concrete surface, and a smaller grinder to do the edge work. They vacuumed thoroughly with a HEPA filter vacuum to remove all the dust, though a lot was sucked up in the grinding process. They had their own 3-phase generator to power the grinder.
After this thorough grinding and cleaning, they mixed up a batch of fast-setting (20 minutes) polyaspartic filler, and filled in the spider cracks. Larger cracks, they filled with a fine sand just to prevent all the poly aspartic from running down the crack. They trowled all of this. Then they mixed up a slow cure polyaspartic (grey color), and when that was down and still uncured, they sprinkled the latex paint flakes all over; these were a mix of black, white and two shades of gray. When it all cured, they used a blade to scrape off all that didn't stick, and vacuumed up the mess. There may have been a spot or two that needed a touch more, and they mixed up a bit of clear fast cure and touched up. When all was cured, they gave it two coats of clear polyaspartic. The dust is dreadful, the vapors from the polyaspartic also harmful so this was all done with respirators.
Now that I live in NC, my smooth concrete floor will likely stay that way; no salt, snow, ice and stuff that comes in from the unbearable Michigan winters.
Several neighbors had it done here, most for appearance sake. If I ever decided that I need to pretty up the garage, I think I would choose James Lester's route with tiles of some kind. A fraction of the cost.
Epoxy slurry, not paint, as recommended above. I've had it for 20 years, and yes, it must be professionally applied with proper prep, equipment and expertise.
Previous garage and one of my current garages.
Hi Katie,
I used Garage Floor paint, but it needs redoing every few years, which is a pain to mask it all up, and move the cars, so I like James`s idea, for the next time.
Paul
Knowing some people do ALOT of work on their cars and trundle around engines and gearboxes on hoists and stands, use trolley jacks and axle stands etc, I am sure epoxy or simular (I know some folk have gone with pavingslab type tiles) would make more sense than a plastic tile.
But for most of us storing our cars and other gubbins, maybe with a leaky gearbox or back axle, and the occasional bit of work such as jacking the car, they work fantastically for the price. They sweep easily, can be damp mopped and they can cover a multitude of sins in the subfloor.
For a home garage that is just going to be used for storing the car, I would go with tiles as James suggested. However, if you're going to be doing any work then, although not essential, a good professionally laid floor will make keeping it clean and finding the little screw that you just dropped so much easier!
I have the Polyaspartic coating in my garage. Not slippery when wet like the smoother, glossier finishes and has a slight shock absorbing quality. Very hard to chip. More expensive but totally maintenance free and mine came with a 15 year warranty. If you are keeping your garage for the long term, something to consider.
I have done 2 epoxy floors myself. It is not that difficult. you just need to read the directions and take your time.
You will save a couple of thousand dollars!
JN
I just had a home built and had a quote for my garage floor and it came in at $4 per square foot. That was just a garage paint. I decided to do my own and used a 2 part epoxy. I used a muratic acid and water solution for the etching per the instructions of the manufacturer and TSP from Home Depot to clean the surface prior to application. Paint cost was approx $100 per gallon but well worth it. Guaranteed for 20 years and from the looks of it it will last. My 2 cents!
until a few years of hot tires sitting on it.
I have 115 sq meters or 1250 sq ft to do in my new garage so either way it’s going to be an expensive exercise but from all the replies, the epoxy looks like a winner.
With thanks to all you wonderful folk for your advice 😁
It seems epoxy may be the way to go, looking at positive comments on that, but then again, it may be down to price!!
Take care out there!
Katie
Many suggestions and experiences shared here, with all being specific to different requirements. (Shop-like floor vs. home garage use) One very important point to consider prior to rolling up your sleeves or emptying out your bank account, is the moisture level of your concrete. This will determine which application is best and going to last without flaking or weakening of the surface material and regretting your product selection. Place a plastic garbage bag on your floor and weight it down with some books or wood. Lift it the next day and see if moisture has accumulated on the surface beneath the bag. If so, your surface coating will be susceptible to flaking as your garage is not weeped properly around the perimeter and moisture is getting under your slab and wicking upward. Select the appropriate product for this type of condition.
I also prefert Epoxidharz
Very good point Bill. I will test the floor as suggested which is a new poured 150mm reinforced concrete.
just to be clean, Garry, an epoxy slurry is not painted on as are epoxy paints or other epoxyXXXXX. Rather, the control joints are filled, the concrete surface is diamond blasted to a virgin surface and then a slurry of epoxy about 1/16" thick is spread over the surface. To that, quartz sand, flakes, whatever, is broadcast, by guys walking around on spikes, into the slurry which then settles into it. Next day, the excess sand, flakes, etc., are swept off and another coat of epoxy slurry is applied. All told, it's about 1/8" thick. It is virtually indestructible. It will suffer impact damage that would damage concrete itself, such as dropping a heavy, sharper object. But, hot tires, brake fluid, oil, grease, you name it, no harm. And, it cleans up beautifully.
John,
You had a hoist in your garage. if so did you do the floor before installing the lift?
The epoxy resin is applied in 3 steps
We had set up the lift first.
First the reinforced concrete, then the lift, then the screed, then epoxit.
John,
Yes, both times. But, it was new construction each time. Not sure it really matters.
Mine is also a new construction and I thought it would probably be better to do the floor first.
Love the hoist through the ceiling..lol I had to completely redesign the roof trusses to gain the ceiling height. Cost a bucket to get the engineering all redone.
The architect mismeasured for placement of the lift (more concrete depth at pads). Fortunately, the post could go into the ceiling and the lift height was unaffected.
It does really depend on the moisture content of your garage floor as Bill pointed out, which comes down to wether the concrete slab has a damp proof membrane ( DPM ) within the concrete, which is usually a thick, non decomposable plastic sheet.
In the UK, if the garage is built within, as part of the house, it is more likely to have this membrane, if it is a detached garage it will be very likely that it does not, particularly if it is an older build.
You do not want to be laying any kind of plastic tile or rubber sheet on to a floor that does not have a membrane, it will result in a large amount of trapped water, much more than just moisture, here in th UK in the autumn / winter month's and moisture even in the spring / summer.
A good epoxy paint laid on a well prepared floor in the summer months is a good option or porcelain tile of which the choice of finish is endless would be another high end option depending on your budget. I have done both for customers / clients in the past with good results.
+ 1 for Epoxy but be aware it is a very very slipping surface ( ask me why.... :-[)
Here is what i have done in an old room for my new garage...
other photos :
I put the epoxy my self in 3 steptimes around 20 minutes each one with a temp around 20 C° because the Epoxy becomes hard very quickly.
The concrete was a new one and need to be very well prepared with no humidity before painting. I live at the seaside and i use before epoxy and since the new floor a dehumudificator ... ;)
While we're on the topic of garage floors, would anyone care to comment on the idea of laying down a heated floor?
Have it in all my garages in the new house. Love it. 60 degrees all winter no matter how cold. And don't forget the drains under each car to catch the snow and water and leave the floor all around the car dry. But in winter you'll need a dehumidifier, can get steamy with the melting snow.
Sorry to chime in late but my floor was done in Stonhard Epoxy. I am HARD on my garage floor. I do everything from Mechanical work to welding and machining. Even dragged an 800 pound milling machine across it and it refuses to chip. I need to re apply at some point because it is covered in overspray from my restoration but other than that it has been aces.
Here's mine. It done by a father and son team from Connecticut.
Underfloor heating is without dought the best and most economical way to heat a garage or anything else for that matter. Have installed it in a very large warehouse and the client still can't believe how cheap it is to run, same for houses. The floor only ever gets warm at best but will heat a very large area.
The floor in my 'garages' back in France is compacted dirt, from past centuries. Very dry, I just sweep off the dust from time to time. There used to be a very large fortress before our house + the stone barns were built on its remains, around 1806, and the floors are likely from the 1400's
What you are talking about, Ray, is "radiant heat" and it isn't any more or less costly to run than anything else. BTU's is BTU's and the cost to generate those BTU's is what you need to know. Right now, in many places, a natural-gas fired system is going to be the least costly. Electrically fired systems will always be the costliest to run.
What thelews showed us is the start of a "hydronic radiant heat system". I used this at my car wash (when I owned one) in a snow-melt or de-icing system, and did the same residentially for my driveway. The former was heated by an 82% efficient, 500K BTU boiler; the latter by a 200K BTU on-demand tankless water heater. The heater for my driveway was twice the size of the furnace (in BTU capacity) and when in operation was in full fire mode for 8-36 hours at a pop. That's a lot of gas. My driveway had 60 tons of concrete in it, (over 54K kg) and NOTHING happens fast. It's slow to heat up. On my driveway (see photo in action) I would turn it on 6 hours prior to a snowfall prediction. Most of that weather forecasting was spot on accurate; we knew what was coming to the Detroit area by simply looking west. What's it doing in Chicago? Well, it will be doing that here in a few hours...
Used inside--a home, a garage or warehouse, is different. The heat is "low and slow" and provides a very soft comfortable heat; but it's slow to react to changes. But the amount of heat a home (or garage) will require is based on heat loss calculations, and in order to meet those needs, you will require a certain amount of BTU/hr in order to meet them. HOW you provide those BTUs isn't really relevant--a gas hot air furnace, an oil fired hydronic baseboard, electric, etc. The efficiency of these products combined with the cost/BTU was the determining factor.
The hydronic is great when you have concrete slab for a floor such as a garage. It's also great if you intend to keep it on a low temperature, and a constant temp as well. One thing to consider is the concept of "thermal mass"; if you keep your garage at say, 60 degrees F, well everything IN your garage over time, will settle to 60 degrees. If you have one of those gas fired hot air heaters--common in garages--and you decide your going to work in your garage one night, well it will be easy to heat the air to 60 degrees, but nothing else will be that temperature...the floor, the walls, the tool chest will all be cold. If you have the floor heat on at a constant temperature you'll get a good thermal mass going. Very comfortable!
And by the way, thanks to EVERYONE for such a great array of photos of garage projects. Very cool. Who knew there were so many choices?
Did that driveway work in a heavy snowstorm? We considered doing it for our courtyard 45 x 45 but didn't. Not sure if I regret it or not. Don't know if it would have worked. We will get heavy drifting in areas because of the swirling wind in the courtyard. In light snow the aprons at the garages which retain radiant heat will melt the snow, in heavier snow it's useless.
Ok, so I’m now very jealous of the garages that you all have, makes mine look very inferior!
And the one with an inspection pit, WOW! Could also be used as a wine cellar.
Thanks again to everyone for all the helpful tips and advice
Katie
One more example. This is my "car condo" and it has the Polyaspartic coating. Kind of a garage away from home if you will. I do not have much square footage at our house for a nice roomy garage, so this takes its place.
Choosing the color of the floor is harder than you may think regardless what system you use. Trying guess what a color on a 600 square foot floor is going to look like given a 6" square sample, is difficult at best. Just like choosing a house interior color, you have to consider all of the colors that will be in there. Most go for more of a dramatic color but can overwhelm the space. I went with a more subtle color and wanted the other colors to show and not just the floor.
Good luck.
we used polished concreet , 7 cm , first remove the old concrete floor , new metal reinforcement in , new concrete filled in , polished it , let it dry out verry longtime , concrete filler first layer , concrete filler second layer , clear coat epoxy filler , 2 layers also , 4 jears later stil going strong
verry happy with this floor , and we clean it once a week with a small automatic cleaning machine , just using water and a little soap
I keep wine in my garage. And the motorbike, 4 bikes, a woodworking bench, a rowing machine, the hardtop and assorted household detritus
No room for the car though.
I went with epoxy paint in my Mancave but l opted for polishing the existing (50y.o) concrete floor in my garage at home.
Wasn’t the best floor to polish but so much easier to keep clean.
Dark epoxy floor - still prefer polished concrete.
bigger flake in epoxy makes it harder to find smaller, dropped objects.
….also hard to find on polished concrete floors. Hides dirt well but also hides other things well.
Yes and no. One can design a system to work in ANY conditions, but you set your parameters to work with constraints. In my case, the limit was the source of the heat: a 199K BTU tankless water heater, Takagi TK-3 to be exact. At the time of build, this was the ONLY model available that was certified for use in a recirculation system; so all the other brands out there (Rinnai, Bosch, etc.) wouldn't warranty a system used in hydronic heat with recirculation; had to do with the robustness of the heat exchanger. But, the biggest limiting factor was the AGA considers anything 200K and above to be a boiler; boilers are much larger, have special licensing requirements for the installers, and certification by the state. A Pandora's box of trouble I wasn't going to dive into. So, I stuck with my 199K unit. By proper design, I should have had about 300K BTU. I had no room for a floor mounted boiler; the Takagi was wall mount and small. All of the plumbing for the system was the same regardless of the heat source, so if at some point I wanted to up my gas usage I could have cascaded these units, and the pumps and plumbing remain the same. An additional heater would have caused an upsize in the gas service which I didn't want to do. I was also severely limited in where these could be vented. The photo shows the heater and some of the plumbing required. There was about 2,000 feet of ⅝" PEX tubing in the 5" thick insulated concrete, divided into 7 zones and it used about 28 gallons of glycol in a sealed system.
Now, most of the time it worked very well. If the snowfall was light, and not falling furiously, it melted as it fell. If a bit heavier, it took time to catch up. Sometimes we helped it with a shovel. Where it fell down was those two winters some years back when we had those "polar vortex" situations. Normally in Michigan, snow fell when it was between 25-35 degrees; you need clouds for snow and when the clouds are present they hold the earth's heat, and the temps stay between that range. With the polar vortex however, we had significant snowfalls when it was near zero degrees. Don't even TRY to melt that with the driveway, it's just burning gas.
Even when the driveway was having trouble keeping up with a heavy snowfall, eventually the snow stops, and the sun comes out. Even in the dead of winter, with a little radiant heat from the sun on the driveway and the driveway going, in short order the driveway was clear AND DRY. I compared that to most people in my neighborhood, who when they had to go to work before they could clear the driveway packed that snow down and ice formed. It created dangerous conditions for driving and walking. My driveway in the winter generally looked like it was July--and it wasn't uncommon to see 2-3' piles of snow on the edges but the concrete surface clean and dry. Often people driving by stopped and stared and said "What the F?"
The lighter snows are a non-issue for us to clean (1000 ft + courtyard). The heavier snows are problematic, and as you noted can be followed by extreme cold. The warmer, wet, heavy snows are a problem too. So, I don't think the radiant would have helped much, not with drifting or 1" an hour storms. Also, the courtyard is on the north side of the house and doesn't get a whole lot of sun.
But it would have helped with ice that forms when we can't blow before driving on the snow.
...The heavier snows are problematic...followed by extreme cold...warmer, wet, heavy snows are a problem too.
It all would have depended on how many BTU's you used to feed the system. Simple as that. If you were able to heat that slab to 35 degrees F--no easy feat mind you--any and all snow touching the driveway would melt immediately and shortly evaporate.
But those quoted items above are exactly why we moved from Michigan to NC. We tired of it after 35 years. Since we've been here--mid March--we've had more lovely spring days than a decade in Michigan. Our old neighborhood had snow 3 weeks ago, and a week ago it hit 90 degrees. We had enough of that; maybe lovely for some, but not for us.
Again everyone, lovely photos and ideas. I've always liked the idea of polished concrete.
Not polished concrete, but concrete with clear epoxy coating. Easier and cheaper than polish. This is not a slurry, a much less expensive coating of clear epoxy for a garage that does not get heavy wear and tear.
I just got a rough price for doing an epoxy floor for the garage and its about AUS$70 a sq mtr which is about $40 USd a sq yrd. How does that compare with pricing overseas.
Interesting comment on finding dropped small items. I am thinking of the attached photo for the floor
Garry, be careful with that colour as you might camo your car so much you can’t find it :P
That’s less than I paid in 2016 by a good bit, for polyaspartic. I think ours was $7/foot or so.
You’ll never find anything you drop on that floor...😉
I pay 3 years ago 30 euros...
Echo this.
I have done three garage floor over the years, and there are two things that kills epoxy floors:
1. Moisture. I say leave the taped section of plastic (about a square foot) for a few days, up to a week. When you remove it, if there is any moisture the paint will loosen, just a matter of time. There are things )and special prep) you can do but I never had to.
2. Chipping, esp from using a jack) with metallic coaster or wheels. A heavy car on a small surface area like that will crap the paint. You can also see the same effect if you drop a heavy and sharp object, it can also chip the paint. Or use a jack stand without anything below it (use a square piece of MDF, or even a thin piece of sheet metal.
As others have said, a (gloss &) lighter shade of beige or blue works well, reflects light and make garage seem brighter, and makes finding dropped things easy.
Just be careful walking into garage in winter with snow on shoes. Slippery, very slippery..... ;)
You need to contact a financial advisor.
This is kind of a poor man's option but I went to this site and bought the vinyl roll flooring in the blue chevron pattern. So far I'm very pleased. Takes no time to put down looks good enough for a space that is recognizable as a garage and was very cost effective.
https://www.rubberflooringinc.com/garage/index.html?slc=2421&utm_source=google&utm_term=&utm_campaign=&utm_medium=cpc&utm_content=s_pcrid_434187981738_pkw__pmt__pdv_c_pprd_2421&gclid=Cj0KCQjw4ImEBhDFARIsAGOTMj8ORINV4-dChUNP7SAL1fCRrHPJ_VwxaCowOKG7qrItC0VX3uvD1yEaApPCEALw_wcB
I took note of the comments on dropping items on the floor and not being able to find them and ended up using a plain grey epoxy two pack and doing it myself for 1/8 of the price and it appears to be fine..
I posted 5 years ago about my garage floor in France. We're here again for July and August, and I have been making some improvements to it. Here's two current photos:
I made and installed the 5-meter (16 feet) long workbench to the right, using planks from a pine tree that grew on the property and we had felled about 15 years ago. I am using the wood from that tree from time to time to make replacement doors and window shutters. I also made the lamp above the workbench, with an led strip made by our Chinese friends.
This Summer, in this space I:
- serviced my 1990 French-made riding mower (with Kawasaki engine and American Peerless transmission), replacing all the belts, blades, serviced the motor etc
- replaced master brake cylinder and front brake discs and did oil and filter change on my 2001 Volvo C70
- replaced timing belt, water pump, accessory belt and pullies on my 2002 Volvo S80
The floor is essentially super-compacted dirt, from the over 5 centuries of people and animals using this space. Originally it was a medieval castle, that was destroyed in fire and storm, rebuilt, destroyed again until the current structures were built in 1806. Parts of the old fortress walls were incorporated into the current structures which is always amazing to look at.
To the right you can just make out the automatic cat feeder system I have set up for the 10 or so feral cats that live on the property. It releases small portions of kibble at set times, the hopper I made for it holds about 20 lbs of feed and our neighbor, the town mayor, comes in from time to time to refill the thing and provide fresh water.
The wall to the left is part of a wood-fired bread oven.
We call this 'the small barn' since one very much larger and taller, that was part of the central castle tower, is also there. Opposite it is the old watch tower with small prison.
wow!
