W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Harry on May 14, 2020, 01:07:08
I am replacing the low pressure PS hoses because the two that I took off had been”sweating” fluid. They were literally leaking along their full length? These weren’t doing that before.
So I’m wondering if I had put Automatic Transmission Fluid in by mistake and if so, could that result with this condition? I don’t think I did but it makes me wonder. Would ATF cause this? And actually, the old hose looks like heater hose, but I have driven the car for years without this being an issue.
Thoughts?
Harry
I thought the power steering fluid is the same as the transmission fluid dexron mercon [sic]
Mine did the same and I replaced the pipes and now it’s ok
Yes, both ATF oil.
For automatic transmission (K4A025) especially ATF Type A - Suffix A, MB 236.2.
For power steering the same or according to MB 236.3/236.7 (236.6H).
...WRe
Great - that's reassuring. Thank you.
The hoses that leak may have been really old or not P/S hoses. There are so many materials in hoses, designed for a specific application and it could be, someone used a hose they had available rather than specific P/S stuff.
