W113 Pagoda SL Group => General Discussion => Topic started by: W14 on May 09, 2003, 13:33:26
Hello All,
I am just about to re-install the exhaust and intake manifolds to the head. Should there be washers between the stud nuts and the manifolds?
Mine just has the nuts, which doesn't seem correct, especially for these "split" manifolds.
Will W14
1965 230SL 4spd
Victoria,BC
On my 1969 280 SL there are washers there. I would not dream of NOT using good quality washers. These manifolds are pretty expensive to replace, and they can break. Also watch for the connection between the manifolds and the exhaust downpipes - overtightening these can also cause breakage.
Ok, thanks Cees - I'll rustle up some washers!
Will W14
1965 230SL 4spd
Victoria,BC
Will,
Go for the original washers and nuts.
I think the washers are quite hard and of course the right outer diameter and the nuts are copper coated.
Sorry part numbers not to hand
hobel 65 230SL
jalopyno 68 280SL
Thanks Naj, I'll check to see what the local MB dealer has.
Will W14
1965 230SL 4spd
Victoria,BC
Will,
Part #s:
N 000125 010532 washer
N 000137 010201 spring washer
A 000 990 3150 nut
happy fitting
hobel 65 230SL
jalopyno 68 280SL
Thanks Naj!
I didn't know about the spring-washers.
Will W14
1965 230SL 4spd
Victoria,BC
