W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: mcclainjlkcmsncom on April 30, 2020, 12:58:04
Title: quick question on warm running device
Post by: mcclainjlkcmsncom on April 30, 2020, 12:58:04
My WRD thermostat extends only 4mm it is not enough to shut off air.I thought I read somwhere that it should extend 7mm.I believe it is the newer type on a M130 1972 engine.Does anybody know the part number and who sells it.
Thank you in advance.
Title: Re: quick question on warm running device
Post by: mrfatboy on April 30, 2020, 13:43:26
Check this out. You might have get a different spacer or modify your exIsting one for newer thermostats.
https://www.sl113.org/forums/index.php?topic=16107.0
Post by: col320ce on May 01, 2020, 12:48:46
Part # 0012039575
Not too expensive either. Sounds like yours needs replacing.
Post by: mcclainjlkcmsncom on May 01, 2020, 18:06:55
thanks for replies.I took it apart and polished alum slide piece and it seems to work better will install it this weekend.
Post by: Pawel66 on May 01, 2020, 18:37:08
Thermostat is available at MB. Not too expensive as mentioned.
Post by: col320ce on May 01, 2020, 22:30:20
Also make sure that the inside of the housing is clean of all the rust that can accumulate there.
Post by: WRe on May 02, 2020, 07:23:53
there are several brands on the market: Mahle -28€, Behr -49€, Bosch -98€ and MB -135€.
...WRe
