W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Pastarnac on April 18, 2020, 21:31:40
Gentlemen,
with all this social distancing I had an itch...
I took apart the linkage to get it zinc plated in my - not so secret lab - basement. Now I have to put it back and I realized that 2 brackets are similar but not identical, see pictures. They is about 1/4" difference between them
Question: Which one goes next to the injection pump, the shorter or the longer one?
BTW. For those who have a similar itch visit :
https://www.caswellplating.com/catalogsearch/result/?cat=0&q=ZN15C (https://www.caswellplating.com/catalogsearch/result/?cat=0&q=ZN15C)
I will check in the garage tomorrow if nobody answers earlier. But I would try if the longer one will fit in the bracket on the inlet manifold side. I think you can try it - it may be too long and will collide with the bracket...
On my car - the longer one is on the injection pump side
Agree: by my crude measurements, note the OEL in the background
Other side:
Thanks to all!!!
The longer bracket is next to the injection pump... I am on a mission.
