W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Harry on April 01, 2020, 22:26:56
Title: Another Identify, Please
Post by: Harry on April 01, 2020, 22:26:56
I had packaged this socket head cap screw in a baggie with the distributor drive gear.  This would normally ondicate that it would be required for that part of reassembly bit I cannot recall or determine where it is needed.  It has the lock washer along with a thicker speciality washer.  Cannot see where it might go.  Thoughts?
Title: Re: Another Identify, Please
Post by: Pawel66 on April 02, 2020, 06:43:38
Is it not the one that holds distributor to its seat? You losen it for ignition adjustment, then tighten it?
Post by: Sead on April 02, 2020, 07:03:16
Power steering pump bracket to alloy oil pan. Needs a space washer beetween them.
See pics.
Post by: Harry on April 02, 2020, 10:23:49
Not the one for the distributor.  I did have good pictures of that bolt and even had it taped to the bracket it goes through.
The PS bracket - yes!  I have no idea how it got "bagged" in the distributor hardware.
This forum is so valuable to the Pagoda community.  Very much appreciated!
Harry
