W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: dnadanny1 on February 10, 2020, 13:20:54
Title: 1966 230SL engine stall & CO too high issue
Post by: dnadanny1 on February 10, 2020, 13:20:54
Hi there!
As the cylinder head was leaking coolant, I have replaced brand new cylinder head and followed "W113 Basic Fuel Injection Linkage Adjustment and Idle Adjustment Procedures" from pagoda SL group technical manual.
When the temperature is 180°F, ignition timing is 5 BTDC, CO is 5-6% and idle 800 RPM, the following issues appear:
1) after I adjusted the CO to 3.5 - 4%, the engine will stall when I decelerate.
2) When I start the car in the morning with environmental temperature being 62°F, the fast idle is only 950RPM.
How should I adjust the fast idle to 1100 RPM and CO to 3- 4% without engine stalled? Should I adjust to the correct RPM first or the correct CO first?
Any comment will be appreciated!
Danny
Title: Re: 1966 230SL engine stall & CO too high issue
Post by: ctaylor738 on February 11, 2020, 13:20:21
"When the temperature is 180°F, ignition timing is 5 BTDC, CO is 5-6% and idle 800 RPM"
At this point I would declare victory and move on.
Post by: dnadanny1 on February 15, 2020, 01:42:29
Thanks for your reply.
When I use smoke analyser to check intake manifold leakage, i discovered that the butterfly shaft contacting switch for automatic has a bit leaking.
May I know if it is a normal circumstance?
Danny
Post by: Tyler S on February 15, 2020, 02:49:31
They all leak a little. As long as the shaft has no excessive play or binding then it is nothing to worry about.
Post by: dnadanny1 on March 02, 2020, 05:13:35
Here is the data I got:
1500 rpm 9.5% CO
2000 rpm 8.5% CO
2500 rpm 0.4% CO
3000 rpm 0.1% CO
Idling in gear 1000 rpm 0.1% CO
Idling off gear 800 rpm 6.7% CO
Thanks a pagoda member Fatboy working with me for the better performance.
I think the constant speed solenoid open more butterfly than the FIP, which makes 800-2000 are too rich. How can I only make CO at 800 - 2000 rpm leaner without affecting CO at other rpm?
When I perform the split linkage test, I tried to open the butterfly slightly, and the rpm did up a bit. That means it is too rich when idling.
Also, the car seems has a slow response to gear switch among 4, Neural and R position.
Any idea? Thanks
