W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: thomasw on January 02, 2020, 19:56:21
Hi!
I'm currently assembling my later short style of fuel pump with the help of the excellent article on the Technical Manual section. It mention that you should test the direction before you proceed, if it is wrong you should turn the motor can 180 degree. But i can't see what the correct direction of rotation is? Anybody that knows that?
Correction: Found the arrow on the cover!
Greetings from Sweden.
Thomas
Welcome Thomas, yes just switch motor connections 180 degrees to change DC motor rotation.
