W113 Pagoda SL Group => General Discussion => Topic started by: RobSirg on December 06, 2019, 12:22:44
Title: Curious. Why the hole in the under dash panel?
Post by: RobSirg on December 06, 2019, 12:22:44
I just had a new set of under dash panels made and the guy who made them for me mentioned about the hole that they have in the panel that sits under the Glove box. We couldn't see any obvious purpose for this hole. Does anyone know why it is there?
Sorry I didn't take a photo but can do so tomorrow.
Cheers
Title: Re: Curious. Why the hole in the under dash panel?
Post by: mbzse on December 06, 2019, 13:22:20
Quote from: RobSirg
.../...under dash panels made and the guy who made them for me mentioned about the hole that they have in the panel that sits under the Glove box. We couldn't see any obvious purpose for this hole. Does anyone know why it is there?.../...
Hole in panel is there in order to allow air from the vent box outlets to reach your feet, when you have set the controls for the air distribution vent (and heat) flaps accordingly
Post by: RobSirg on December 07, 2019, 00:06:20
Thanks for your reply Hans,
Just to be clear - l am referring to 2” hole in the photo.
Rob
Post by: Benz Dr. on December 07, 2019, 06:18:51
That's strictly for fresh cold air. No heated air from those vents.
Post by: RobSirg on December 07, 2019, 09:25:13
So fresh air ( intake ) for the blower?
That makes sense - albeit a little agricultural.
A grille / louvre would have finished it off for minimal cost.
With all the wonderful design elements in these cars l think we can overlook this one.
Rob
Post by: merrill on December 07, 2019, 14:36:58
interesting the things i continue to learn from this form.
My 66 230 has never had the underdash panels,  looks like Sls has them.
Post by: mrfatboy on December 07, 2019, 16:27:11
@merrill
Vintage Euro Parts sells them also or you can can make them yourself. I put the templates in tech manual a while ago.
I have more detailed pictures if you need them.
I covered them with MB Tex to match my interior.  Maybe you have some left over when you did your soft top cover.
See this thread.
https://www.sl113.org/forums/index.php?topic=27312.0
You will have to adjust the templates for autos and 230's. Simple to do.
Post by: merrill on December 08, 2019, 01:24:19
MrFatboy
thank you ,
what material did you use for the panels?
Post by: mrfatboy on December 08, 2019, 01:42:27
I bought 10mm on eBay. MB Tex from GAT. The actual board I bought from a local upholstery shop.  It was a complessed 1/8" (?) fiber board that I think was water resistant.  $14 for  a 3'x4'piece.
I used 3M spray can glue from Home Depot to glue both foam and MB Tex to the board.
Please note that the foam overhangs the board as seen in the picture.  The foam is to be trimmed to sized depending in fit.  Notice that 3rd party vendor panels are sold with over sized foam.
For a small detail I split 1/8" plastic piping in half and placed it on both left and right panel bend points to mimic the originals. Remember to score the fiber board at the bend points.
Post by: Benz Dr. on December 08, 2019, 05:06:05
Rob
No. Not for the blower which has no effect on the side vents. Simple system that when you open the side vents and close the louvers air will come out of those round holes in the under dash panels. Your fresh air flap at the outer base of the windshield must be open but generally speaking it's left open anyway or nothing will work very well.
Post by: RobSirg on December 08, 2019, 08:52:30
Oh yes ....simple indeed.
Thanks for the explanation
Rob
Post by: stickandrudderman on December 09, 2019, 16:09:37
It's where the OBD socket should go...... ;)
Post by: RobSirg on December 09, 2019, 22:15:18
Ok I’ll bite .......what is an OBD?
Rob
Post by: mdsalemi on December 09, 2019, 22:55:11
On Board Diagnostics. All cars have them today.
https://www.carmd.com/obd-port-location/
And, Stick is correct...IF our cars had one, it would probably be right where that hole is!  ;)
Post by: Benz Dr. on December 09, 2019, 22:57:04
Trust me, neither of us would fit under the dash of a 113.  :)
