W113 Pagoda SL Group => Wanted To Buy => Topic started by: wwpepper on November 16, 2019, 02:25:50
Title: 6 bolt torque converter (3x2) needed
Post by: wwpepper on November 16, 2019, 02:25:50
I am looking for a torque converter for a 230sl automatic. It is the 6 bolt design, three pairs of two bolts.
I prefer the version with the welded hub over the aluminum or riveted hub versions, but will consider all, even ones needing repair.
Thanks.
Title: Re: 6 bolt torque converter (3x2) needed
Post by: Tycoon on May 09, 2020, 03:02:39
Not sure if you still need this. Had mine rebuilt for $250 CDN dollars @ Convertor Man. You can find them online in Etobicoke, Ontario Canada.
Hope this helps,
Bill
Post by: ricSL on May 09, 2020, 12:58:34
I have one listed on Ebay 233581551329 this one with ears and some rust and condition unknown also rivetted version, if interested call me 775 830-3304.
Ric
Post by: Benz Dr. on May 09, 2020, 17:25:37
You have the later transmission if it has 6 screws. I just finished a '66 230SL and it had a flywheel with 4 screws.
Post by: MikeSimon on May 11, 2020, 15:44:05
I didn't think our SLs had "torque converters"? They are hydraulic clutches...?!?
Post by: mbzse on May 12, 2020, 11:19:05
Quote from: MikeSimon
.../...They are hydraulic clutches...?!?
Right you are  8)
