W113 Pagoda SL Group => General Discussion => Topic started by: Shvegel on September 26, 2019, 09:34:57
I am about to put the under dash area back together and the problem I have is I didn't take it apart. I am wondering if anyone has a rough outline as to the order things go back together? I figure the firewall pads then Wiper linkage and then heater box but wanted to be sure before I end up messing up and having to backtrack.
That order worked on my project.
BR,
Matti
Just been doing the same thing the past couple of weeks.
That is the order i did.
Next i refitted the wiring loom, heater blower, heater cables/ fresh air flap, washer hose routed through dash, steering box and column.
( note the cardboard demister vent above the column should go in before the column. I forgot to but intend to rectify this next time i go in the garage.
Are you installing a new firewall grommet on your wiring harness? I have a trick for doing that without removal of any connectors on the harness.
Frank,
please share it.
I still have to do it, so tips ar welcome. ;D
I am starting the same process right now so this list is extremely helpful thanks?
Thanks everyone for chiming in.
Waltklatt, Wow. Sounds like you have done this a time or two. Thanks for detailed checklist.
That reminds me to order a little MBtex.
Since a few have asked for my tips on replacing the firewall grommet, I will create a separate post under the electrical section. I will put a description and link to my google photo album there. Before you start, you will need to get a 1-1/2" and 1-1/4" sink "tail piece" from your hardware or home improvement store.
I am at the same point on my car so I appreciate any and all input.
