W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: silver surfer on June 01, 2019, 19:23:43
I have just had my bezels back from the chromer and one of the riveted top spring clips has corroded at the end which means I cannot successfully attach it to the car. Thinking of finding a way to repair it unless they can be purchased?
Any advice would be gratefully received :(
The matter was discussed in this thread
https://www.sl113.org/forums/index.php?topic=26372.msg189859#msg189859 (https://www.sl113.org/forums/index.php?topic=26372.msg189859#msg189859)
Thanks for that very useful link. Are the spring clips / brackets available to buy sperately as it is one of these I need to replace?
Thanks again
Problem solved!
I managed to make a new steel tab and carefully MIG welded it to the existing clip.
Sounds nice; can you post a picture of the repair?
Ashley, I was going to write that these parts are difficult to find. For the spring clip I was looking for a bezel in a bad shape to buy it and take it from there as I was not skilled enough to fabricate it.
For the little tab with threaded hole for the bottom fixing - I fabricated it.
Good you managed to fix your spring clip!
