W113 Pagoda SL Group => Electrical and Instruments => Topic started by: merrill on May 27, 2019, 17:02:48
hello
this may be a 2 part question
I purchased a spark plug wire guide tube bracket for my car, the wires run inside the tube and then come out the bottom see photo
question is should i be able to run the wires in the tube with out removing the ends. I am talking about the 90 deg end that plugs into the distributor cap
if not, how can i remove an end of the spark plug wire to be able to run the wire in the tube and then re connect the end.
i may be over cautious here.
thanks in advance matt
Hi Matt,
I think you should not have the plug leads with 90 degree ends if your car uses this kind of guide.
I recently fitted new plug leads with straight ends and they were simple to push through.
One or both ends should unscrew.
