W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Minerva on May 20, 2019, 22:42:24
I have a small weep of oil at the lower timing chain guide pins, the two between the power steering pump bracket and the distributor gear cover.
Two questions, how do you seal these and if I've to take them out to seal can I remove and refit them one at a time safely.
Thanks Keith.
