W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: CJHenderson on August 08, 2018, 20:32:23
Title: Rear axel outer bearings difference
Post by: CJHenderson on August 08, 2018, 20:32:23
Is there a difference between right and left axel outer bearing? On my 280 the left bearing is a ball type and the right one is a roller type.
Title: Re: Rear axel outer bearings difference
Post by: Pawel66 on August 08, 2018, 20:59:30
Yes, significant difference. Right one is a self-centering one. Please use search function, type in "rear bearing". You will find all the information on type, replacement etc.
Post by: CJHenderson on August 09, 2018, 00:51:23
Thank you for pointing in the right direction, that helped immensely.
