W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: RichieScotland on August 05, 2018, 18:57:35
Title: Engine Backfires on idle
Post by: RichieScotland on August 05, 2018, 18:57:35
Hi
My 230SL has started to backfire on idle and is running rough. I have tried adjusting timing which looks correct - any ideas where to go next - injectors? injector pump ? valves ? Any clues gratefully received !
thanks
Richie
Title: Re: Engine Backfires on idle
Post by: Rolf-Dieter ✝︎ on August 05, 2018, 19:45:11
I recommend to first check your linkages
Here —— > https://www.sl113.org/wiki/Restricted/Linkage-tour
Post by: Mike K on August 06, 2018, 20:32:25
Check that your ignition cables are not faulty as well as spark plugs.
This can also be a cause, especially the rough running.
Mike
