W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Rolf-Dieter ✝︎ on May 12, 2018, 17:38:52
Title: Grease lubrication plan with Photos
Post by: Rolf-Dieter ✝︎ on May 12, 2018, 17:38:52
I came across this "Grease Lubrication Plan" might be helpful for some of you out there (perhaps to make sure your local mechanic does not miss important points).
Anyway, I translated the German to English here it is;
Schmierplan Abschmieren:
(Grease lubrication plan:)
1)    Motorölmeßstab = Motor Oil Dip Stick
2)    Zündverteiler = Distributor
3)    Wasserpumpe = water pump
4)    Öleinfüllstutzen = Oil Filter
5)    Ölablasschraube = Oil drain plug
6)     Unterer Querlenker li/re = Lower wishbone left / right
7)     Oberer Querlenker li/re = Upper wishbone left / right
(8)Achsschenkel li/re = Steering knuckle left / right
9)    Oberer Querlenker hinten = Upper wishbone rear
10)  Zwischenlenkhebel = Between the steering lever
11)  Wechselgetriebe = change gear
12)  Gelenkwelle vorn  =  PTO shaft front
13)  Gelenkwelle mitte =  PTO shaft center
14)  Hinterachse = rear axle
15)  Lenkgehäuse = steering housing
16)  Vorratsbehälter Bremse = Reservoir brake
17)  Vorratsbehälter Kupplung = Reservoir clutch
18)  Türscharniere = door hinges
19)  Vorderradlager = front wheel bearings
20)  Einspritzpumpe Ölstand = Injection pump oil level
Photos are a bit small, however, one can always enlarge them a bit more.
Sorce: Pagode Info
Title: Re: Grease lubrication plan with Photos
Post by: Iconic on May 12, 2018, 17:48:45
Also, I believe it is in your glove box operators manual.
Post by: Rolf-Dieter ✝︎ on May 12, 2018, 18:41:43
Problem is, not everyone has one. I only have the Owners Manual for the 280SL
Post by: Jowe on May 12, 2018, 18:51:53
And, you will of course find it in the Enthusiastic Pagoda Service Manual - in English  ;)
https://www.sl113.org/wiki/Restricted/ServiceManual
Post by: Rolf-Dieter ✝︎ on May 12, 2018, 20:29:55
Thank you Jowe!
Goes to show you I’ve been here over 5 years now and never came across this wonderful write up, thank you! Great photos too.
Dieter
Post by: Garry on May 12, 2018, 23:12:38
Another item that Full Members have access to and worth the cost of Membership.
 It answers many questions that are asked on the Forum and is a “Must Have” if you do your own servicing and any other general repairs to your Pagoda..
 ;) ;)   ;D
