W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: gordon on March 26, 2018, 19:08:12
Title: At 5 speed gearbox
Post by: gordon on March 26, 2018, 19:08:12
I have bought a 1975 car with a ZF 5 speed gearbox which I believe is the same as fitted to a 113. The gear change is almost impossible at times although a new clutch has allegedly been fitted.
Have any members in the UK had a ZF repaired and if so was it expensive?
Title: Re: At 5 speed gearbox
Post by: mbzse on March 26, 2018, 19:13:23
Quote from: gordon
.../...a ZF 5 speed gearbox which I believe is the same as fitted to a 113.../...
Well, does your gear box look like this?
Post by: gordon on March 26, 2018, 20:00:35
Hi Hans, I'll check tomorrow. The shift pattern is the dog leg, ie  first gear is bottom left  second is upper right.  Is this the same as fitted to 113?
Post by: mbzse on March 26, 2018, 20:06:54
Quote from: gordon
.../...The shift pattern is the dog leg, ie  first gear is bottom left  second is upper right.  Is this the same as fitted to 113?
Post by: gordon on March 27, 2018, 17:49:43
Ok, so it seems that my at box is different to the Pagoda box. Are parts still available for repairs?
Post by: swood1 on March 29, 2018, 08:51:46
Gordon,
Are you sure you have the correct 5 speed gearbox on the car?
Steve
