W113 Pagoda SL Group => General Discussion => Topic started by: Gary Best on March 12, 2018, 18:52:37
Title: Dropping Steering column
Post by: Gary Best on March 12, 2018, 18:52:37
First post - can any of you guys help - I'm stripping my 230sl and I having trouble dropping the steering column - I have undone the two nuts hold the strap but the strap does not want to pull away from the dash it seem to get held up in the box section - I'm I missing something?
Rgd's Gary
Title: Re: Dropping Steering column
Post by: doitwright on March 12, 2018, 19:18:42
Oh you NewB's. Welcome Gary. Use the search function. Here is a start:
https://www.sl113.org/forums/index.php?topic=17841.msg124058#msg124058
Post by: JamesL on March 12, 2018, 21:00:43
Welcome Gary
Post by: Mike H on March 13, 2018, 06:03:10
Hi Gary,
I would say the threads are binding on the side of the hole.Give the threads a bump with a piece of wood or something that won't damage the thread, while moving the column out side the dash.
Also loosen the clamp ring at the base of the column.Even if you get the strap loose, the ignition key bezel wants to sit against the hole and ring escutcheon in the dash,so movement in the steering column is usually limited and difficult.
Good Luck.
Mike H.
1964 230 SL Auto RHD 2 Tops...under restoration.
Post by: Gary Best on March 13, 2018, 06:58:48
Mike Thanks - was going to do that but thought I'd better check first - Gary
