W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: CJHenderson on July 11, 2017, 01:15:22
On the right side of the transmission tunnel is a cover plate. Is this normal because it doesn't look like Mercedes workmanship?
That is a factory plate. It allows you to access the three position solenoid linkage(Automatic transmission cars) and bell housing bolts.
Ok thanks.
If I may add my 2 cents - the opening in the tunnel is, certainly, a factory opening, it also allows you to undo one of the starter screws that otherwise is difficult to access.
What I am not sure about, just judging from the picture, is if the actual cover I see is an original one (not sure if that is what Shvegel meant - was it about the whole opening/cover plate arrangement or the cover plate itself - if the latter one, he knows better than me). I do not remember now, but I think mine looked a bit different, I think it had some moulded shape around its edge... but I may be wrong.
looks like the one on my 66'. nothing fancy just a metal cover.
